del
Публикувано: 14 май 2012, 20:23
				del
			КЛУБ ФОРД БЪЛГАРИЯ. Резултат от обединяването на ford.co.nr/forum и clubford.org/forum
https://clubford.org/forum/
Така се обучава трети ключ да пали колата ако имаш два работещи. Ако не вкараш третият ключ на точка 4 се изтриват всички други обучени ключове.1. Insert an existing (working) key into the ignition cylinder.
2. Turn the ignition cylinder ON (RUN) and back to OFF. Ignition should stay on for at least ONE SECOND.
3. Remove the existing key and, within TEN seconds, insert a second working key and turn it to ON (RUN) and
the back OFF. Ignition must be in ON for at least ONE second, but no more than TEN seconds. Remove
the key.
4. Insert the new key before TWENTY seconds have elapsed and turn it to ON (RUN). Leave it the ON position
for at least ONE second and turn back to OFF.
5. The security light will light up for THREE seconds to indicate that the new key has been successfully
programmed.
6. To program additional keys, repeat steps 1 through 5
Успех!Focus
Note:
A maximum of four keyless entry remote transmitters can be programmed to the central security module (CSM). Programming must be done at the same time for all the transmitters.
Note:
To enter programming mode, make sure that the vehicle battery is fully charged and the anti - theft system is not armed or triggered (if equipped).
1. Close all doors and fasten the safety belts to make sure conflicting chimes do not sound during programming.
2. Turn the ignition switch from position I to position II at least four times in six seconds.
3. Turn the ignition switch to position I.
4. The CSM is now in the learning mode.
5. Press and hold one of the buttons on the remote transmitter until a chime sounds. This indicates a new transmitter code has successfully received.
6. After each successful programming is completed, another 10 second learning mode is automatically entered, up to a maximum of four times.
7. To program additional transmitters, repeat from step 5.
8. The system will leave the learning mode after the ignition switch is turned to position III, or if no new transmitter is programmed during the 10 seconds, or if four remote transmitters have been programmed.
Note:
An incorrect programming procedure does not effect the stored codes.
9. After successful programming, only the new programmed transmitters will be accepted.
10. Test all the programmed transmitters, by activating and deactivating the locking/unlocking functions.
Focus Built from 12.2000 Onwards
Note:
The ignition must be turned off before attempting to reprogram the key fob.
11. The unlocking mode can be changed by pressing the locking and unlocking buttons on the remote transmitter simultaneously for a minimum of four seconds.
12. The change is indicated by the turn signal lamps flashing twice.
13. The mode can be carried out as often as required by repeating step 11.
