Ford Focus 99 грешки
ALIEN_Y2K
Регистриран: 14 май 2008, 12:18
Модел на автомобила: astra g
Мнение от ALIEN_Y2K » 16 май 2008, 21:42
Днеска гледах един фокус и ми даде тези грешки на борд пц-то . Ако някои може да даде повече инфо за какво точно иде реч.
... deleted images by user's site...
Foto Face Photography
cenzor
Местоположение: СОФИЯ
Re: Ford Focus 99 грешки
Мнение от cenzor » 16 май 2008, 21:51
http://www.focusfanatics.com/forum/show ... hp?t=59286" onclick="window.open(this.href);return false;
Additional DTC codes:
9202 Fuel Sender Open
9204 Fuel Sender Short to Ground
9213 Anti-Theft Number of Programmed Keys is Below Minimum
A103 Antenna Not Connected / Defective Transceiver
9317 Battery Voltage High
9318 Battery Voltage Low
9342 ECU Is Defective
9356 Ignition RUN Circuit Open
9364 Ignition START Circuit Open
9600 PATS Ignition Key Transponder Signal Is Not Received / Damaged Key or Non-PATS Key
9601 PATS Received Incorrect Key-Code From Ignition Key Transponder (Unprogrammed Encoded Ignition Key)
9602 PATS Received Invalid Format Of Key-Code From Ignition Key Transponder (Partial Key Read)
9681 PATS Transceiver Signal Is Not Received (Not Connected, Damaged, or Wiring)
A103 Antenna Not Connected � Defective Transceiver
A139 PCM ID Does Not Match Between HEC and PCM
A141 NVM Configuration Failure (No PCM ID Exchange Between Instrument Cluster and PCM)
A143 Odometer NVM Memory Failure
5284 Oil Pressure Switch Failure
1197 SELECT/RESET Switch Circuit Failure
D011 SCP (J1850) Invalid or Missing Data for Engine Air Intake
D027 SCP (J1850) Invalid or Missing Data for Engine RPM
D041 SCP (J1850) Invalid or Missing Data for Vehicle Speed
D073 SCP (J1850) Invalid or Missing Data for Engine Coolant
D123 SCP (J1850) Invalid or Missing Data for Odometer
D131 SCP (J1850) Invalid or Missing Data for Fuel System
D132 SCP (J1850) Invalid or Missing Data for Odometer
D147 SCP (J1850) Invalid or Missing Data for Vehicle Security
D148 SCP (J1850) Invalid or Missing Data for Audio Control
D262 Missing SCP Message
:roll: Не знам,аз го схващам като липсващи данни от скоростомера и за натрупаните километри ( тоест може би някой си е "играл " .. с тях) ?
Последна промяна от cenzor на 16 май 2008, 22:00, променено общо 2 пъти.
debug
Мнение от debug » 16 май 2008, 21:58
Не мисля, че това са грешки... Това са стойности на различни параметри. Грешките са с четирицифрен код и се редуват с dtc. Като го пробваше след dtc изписа ли NONE?
ALIEN_Y2K
Мнение от ALIEN_Y2K » 17 май 2008, 00:42
Такова None немернах но като пробвахме колата стрелката на скоростометара не мрадна от 0 и се чудя сега има ли смисал да се купува такава кола и колко
пари ще излезе поправката на това нешо в мотофое.
Иначе продавачът е навит да го оправи за негова сметка,ако ще сам я купувал със сигурност.Ама маи няма да е ,че и други проблемациики имаше по колата... :? :cry:
debug
Мнение от debug » 17 май 2008, 23:04
Това, че стрелката не мърда от нулата обикновено не е фатално (развален датчик за скоростта - VSS-цена 80-220 лева според двигателя 1,6 - 2,0 литра). Ако стрелката не мърда при теста в режим GAGE - развален приборен панел. Така или иначе тези кодове на грешки са ориентировъчни и реална информация можеш да получиш само при тест с диагностична апаратура - примерно в Мото Пфое. Лошото е, че там имат правилната апаратура, но не винаги с нея работят правилните хора.
izrotbg
Регистриран: 06 юни 2008, 14:23
Модел на автомобила: Focus 1.8i 16V Ztec '99 <= мойта шейна
Мнение от izrotbg » 10 юни 2008, 12:51
-= наи 4есто това се получава като вартят електронните колометражи при внос от чужбина, запояват нещо не като хората и почва да се ебава сега един фр има подобен проблем и трябва да си смени цялото табло ...
-= JusT Me *** =-
ALIEN_Y2K
Мнение от ALIEN_Y2K » 23 окт 2008, 09:39
В крайна сметка си взех Астра Г,която ест. си имаше разни дребни забележки но пак мн радва :)
Prizrakat
Регистриран: 26 авг 2011, 07:06
Модел на автомобила: focus 1.4
Мнение от Prizrakat » 03 дек 2011, 16:59
9202 Fuel Sender Open това пише при мен какво трябва да означава това ?
OgiDogi
Мнение от OgiDogi » 04 дек 2011, 10:07
Prizrakat написа:9202 Fuel Sender Open това пише при мен какво трябва да означава това ?
Че при проверка на веригата, не открива помпата в резервоара - прекъсната (отворена) верига. Възможната повреда е прекъснат проводник, измъкнат/окислен куплунг или изгоряла помпа. Вдигаш на подемник, оглеждаш проводниците, изкарваш куплунга да го напръскаш с контактен спрей и го набутваш обратно на мястото му. Докато е изваден, проверяваш с оммер съпротивлението на помпата, трябва да е нещо от порядъка на не повече от 10 Ω.
ДЕ-РУСИФИКАЦИЯ
unrealxxx
Регистриран: 08 мар 2015, 16:48
Модел на автомобила: ford focus mk1
Мнение от unrealxxx » 03 ное 2015, 12:34
Привет. Ако може някой да помогне и да ми каже какво значи NOx Sensor Circuit. Изписа ми грешка p2200. Фокуса е 99та 1.6 бензин-газ. Мерси.
Мнение от madboy » 03 ное 2015, 18:02
Ламбдата, или е прекъсната веригата към нея.
Потребители, разглеждащи този форум: Google [Bot] и 40 госта
