Kак се въвежда кода
toko
- Регистриран: 31 яну 2005, 09:27
- Модел на автомобила: Mondeo MKI 1.6 16V
Kак се въвежда кода
Някой може ли да ми помогне как се въвежда кода на радиото на форд. Имам оригиналния код, но по никакъв начин не мога да го въведа. HELP!!!!
- Brock
Това тука също е важно.
Ако на някой му се превежда, нека да го преведе
I know I have the correct code but the radio does not do anything when I try to enter it.
It is likely someone has tried to enter a code or accidentally entered a number by pressing the radio preset station buttons. Most radios will enforce a delay between code entry attempts which increases (doubles in some cases) with every try. These radios need to be left switched-on, completely untouched, until they are ready to accept the correct code. Others give a maximum number of attempts - usually 10 to 13 tries after which the radio must be decoded.
Blaupunkt radios will often enforce a delay of 1 hour between code entry attempts during which time be careful not to press any keys or the 1 hour waiting period begins again. The display should change after the hour, indicating it is ready to take the code.
